TSW's and z32 brakes
EnzoRWD
Car: 1997 Volvo 850 T5
Although i will find out in a month when i try to fit them, will 30mm z brakes fit under these wheels ? will i need spacers?TSW stealth. i dont know offset, they are shod with 225/50/16 nittos right now...pic:
ty-Enzo
Exar-Kun
Car: 2005 350Z
I would think not, it all depends on the clearance of the caliper, and that really cant be proven until you mount the wheel on the car..I've seen 17" wheel rub calipers on the 300zx conversion.-chet
EnzoRWD
if clearance is an issues, 5-10mm spacers and longer studs would prolly solve it, right?and if i bump out the front, i obviously have to widen the rear track as well. correct?-Enzo
Chingon
Car: 1991 and 1992 hatchbacks
mine have a similar spoke design and are 15's. I test fit them the other day and they cleared w/like an inch to go. On 26mm however.
