TSB: wet floor?
robj80
Car: 2014 Nissan Frontier
2011 Nissan Rogue
Component Description:1. STRUCTURE:BODY Bulletin Number: NTB-09-010 Bulletin Date: FEB 2009 Vehicle: 2009 Nissan Versa Summary:NISSAN: CARPET WET ON DRIVER SIDE ONLY. WATER HAS LEAKED ONTO THE DRIVER SIDE FLOOR. ( NHTSA ITEM NUMBER - 10027864 )
Just wondering if anyone had any info on this? I may be jumping the gun but I thought I saw some water on my all weather mat yesterday. Most likely it was the water that came off my shoe but just incase I am in seek of info on the wet floor tsb.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
It has to do with some misplaced sealer on the inner body fender near the engine compartment. When it rains, the water runs down the drain channel in the body and has the potential to come in the holes behind the kickpanel by your left foot.
robj80
2011 Nissan Rogue
My little puddle was off center to the right. Exactly where I rest my heal. So I am assuming it's not the seal. Thanks for the info. I will check the panel tomorrow as it will be the third day raining here just to make sure I don't have this problem.
BTW this should be fixed under 3/36000 warranty correct?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
robj80 wrote:BTW this should be fixed under 3/36000 warranty correct?
It applies to all '07, '08, and '09 up to VIN 9L440355. Check the last 8 digits of your VIN number to be sure you would be covered. If yours is lower than the 440355, it would be covered. If it's higher, then you should not have the problem from the factory.
robj80
2011 Nissan Rogue
3N1CC11E09L448777 guess I'm all set
