Trying to use Sr20 slave cylinder
goixiz
Car: Cycling and cars
I didnt install the slave clutch cylinder from my SRsince i have some problems in 1st and 4th gear
I decided this evening to use thc SR clutch and i found that is an additional bo with hard lines goin to it and a looop of tubing that goes to the back for a foot and back into the unit--> WHAT IS THIS ???
I detach it and installed both the slave and this box onto the car. I bleed the oil from both the slave and this box. But seems the clutch pedal went to the floor and the slave did not move.
IS there a specific way to bleed this box or is the box "bad" ?
Do i need this box ??? What does it do ??:confused:
goixiz
The slave cyclinder is a tad longer and 3/4 in dia larger than the stock (which is 11/16)
the_invisible
i think you are talking about the clutch line dampener??
just remove it and you can bleed your clutch.
