DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Sat Feb 23, 2008 12:52 pm
I went to the track a few months ago only to realize that my wheel hop was so bad at the track that I couldnt go WOT in 1st gear. Of course, it wasnt very bad on the street.
I had this problem before, with my stock suspension, I installed KYB AGX's and whiteline lowering springs.. It got a little better, and then I installed some Subframe bushing collars and RUCA's, and the wheel hop was gone.
I dont know where to look next...
Rear traction arms?Rear toe rods?Rear Lower control arms?Rear spindle bushings?
All of those maybe?
I could either buy one set of rear arms (toe/traction), or get a energy suspension bushing kit and do a GRIP of work until all the bushings are replaced...
Which bushings/arms would you look at first? I get under the car with a pry bar and try to find loose ones, but they all feel the same, and not very loose at all..
Thanks for the help..
-Max
