trying to put 94q45 seats in my 90q45
yiannitQ45
Car: 1990 Q45 (R.I.P)
Fairfield,CA
has anyone done this before?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Are you trying to put the entire seat in there or just part of it?
The entire seat will NOT match up with your OEM wiring. You can only use the the cushion and some of the motors.
the 1994-1996 Q45 uses a LAN system where the 1990-1993 Q45 was much simpler and much easier to work with. Plus the colors change on 1990-1992 and 1993-1993 Q45's.
In short you can use the cushions if you get the rear seats to match. You can also use the power lumbar motor as well but it won't work with the OEM Auto Driver Positioner, Unless someone finds a way to fix that.
yiannitQ45
Fairfield,CA
i was thinking about swapping the brackets and motors because it seems like the backrest motor connector will fit or i will replace what do you think?
Infinitiguy19
Not sure on the frame or the other motors. The other motors may fit but the connectors on them may be different because the seats use a different control unit than the earlier (90-93) seats.
Does your seat have power lumbar?
Is it a heated seat?
yiannitQ45
Fairfield,CA
the original seats dont have power lumbar but i think the 94 drivers seat does not sure if there heated either
Modified by yiannitQ45 at 8:15 PM 1/28/2010
Infinitiguy19
I was talking about the 1994 seats. If it does can you take a picture of the switch and motor?
yiannitQ45
Fairfield,CA
will do ill send it to your email since i cant post on the forum because i dont know how
