Ilya »
https://forums.nicoclub.com/ilya-u159401.html
Thu Apr 04, 2013 5:57 am
Right. If you are OEM HID and someone didn't install them after the fact for you, you will need D2S bulbs. Otherwise, I believe it's H1 (check the FAQ thread in my SIG to confirm).
Regardless, 99% of OEM HID's like ours are about 4300k 35w. Get that and you'll be all set. Also, check out the Morimoto bulbs on TheRetrofitSource.com I would change both sides because as HID bulbs get old they 'wash out. So if you get just one new one (from ANYONE), it won't be 100% matched as your old bulb is probably a bit faded.
