Unless you're running a 4 cylinder or the engine is just naturally unbalanced, it shouldn't vibrate that much. I'd make sure everything is in spec if you have a V8 and it vibrates that much. Even a lot of the V6's don't vibrate all that much.
Kamin wrote:racecar - solid engine, SOFT TRANSMISSION. very important that the trans stays soft and you dont solid mount the entire thing.
I've always heard that you're not supposed to mix soft mounts with solid mounts... why do you want to keep the transmission mount soft? If you have solid motor mounts it shouldn't really be moving anyway but by allowing flex in the transmission mounts if there was a lot of force put on it, it seems as though the motor mounts would see unneeded stress.
