trying to locate bleeder valve for clutch on 91 nissan 240sx
jlewis8924
Car: 91 nissan 240sx standard
whats going on with my clutch is i just had my buddy put in new clutch but he didnt bleed the clutch and now my pedal is almost to the floor grabs gears fine no slippage or anything but it dosent feel normal and im pretty sure it's because clutch wasnt bled someone please help ive already came out 600 bucks for parts and labor of new clutch
Reason: Revised title
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Moved this to 240 tech forum.
The bleeder valve is located on the slave cylinder.
jlewis8924
thanks a lot
PapaSmurf2k3
Site Admin
Bleeder is on slave, slave is on the passenger side of the transmission/bellhousing.
There's also a clutch pedal height adjustment on the actual pedal itself. There's a jam nut and a mechanical stop that you can move. You can also adjust the fork on the master if you need to move it more.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Does the vehicle still have the clutch damper?
If so, I'd remove it, it makes bleeding the clutch system a lot easier and the clutch will have a better feel.
corey170
Car: 91 240sx 5spd KA24DE h/b (current)
89 240sx A/T 2.4L (old)
definitely remove your clutch damper (http://garage.projectraine.com/content_ ... amper.html). bleeding with the damper still attached takes forever (or so I hear) and it feels waaay better without it IMO. free and easy "mod".
