Trying to identify this noise from engine bay
Portugese Bend
Car: 1995 S14, 2003 CT9A
http://www.youtube.com/watch?v=oOYbEQ8ikfA
Sounds like it's coming from the fan area. Maybe the water pump bearing (or the fan clutch)?
Modified by Portugese Bend at 9:12 PM 11/8/2007
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
sounds more like upper chain guide noise to me. try picking up a stethoscope at a parts store and checking to see if noise is coming from timing case or water pump.
yosidamasashi
driftingmy240sx wrote:sounds more like upper chain guide noise to me. try picking up a stethoscope at a parts store and checking to see if noise is coming from timing case or water pump.
I agree with him. I do have the same issue, too.my engine has 186k and bought it at 183k, but so far so good...
alexh
I have that noise also on a 92 with 175k miles.
I assume the parts cheap but you have to pull everything off of the front of the engine to get to it?
driftingmy240sx
just remove the valve cover then its just 2 bolts holding the uppe guide on. with high miles you may have more that 1 noisy guide.
Portugese Bend
Thanks for all the replies. Yeah, my KA has 185K on it.
I'll look at the guide when I get the chance. Too much going on right now.
