dhen »
https://forums.nicoclub.com/dhen-u100551.html
Wed Jul 08, 2015 9:06 am
Hi,
I'm usually over in the CA18DET section, but I'm trying to help out a friend. He has a 98 (later model) 4X4 QX4 that has a bad engine that he wants to put a junkyard engine into. I've pulled engines many times, but I've never messed with a QX4.
Anyway, I have a couple of questions. I'm sorry if these sound too basic, but I haven't been able to find the info I was looking for when searching junkyards.
1) I'm finding very few engines on car-part.com for this car. Are there any Pathfinder engines which will interchange with the QX4? Car-part.com only had engines from the QX4, but I suspect that the Pathfinder engine is the same or can be easily adapted to fit.
2) How much time realistically would I need to pull this engine? As I said, I've pulled engines before, but I've never messed with this kind of truck.
Thank you,
Darian
