OguraPowerTuning wrote:i ordered the compleat engine gasket and seal kit today, i got the one for the 88 pulsar 1.8. i assume this is the correct kit. and i was trying to get rod bearings and piston rings but im not sure what to ask for. can i use ca18de rod bearings from the pulsar, if so they said there are a couple choices and i need to know exactly what i need. finally what piston rings do i use on my stock pistons and stock bore?
Everything you need for your rebuild should be ordered from the 1988 pulsar to include the water pump, rod bearings, main bearings, and rings. And they should all be ordered in standard size..........
Dee
