Trying to find S14 SR Long Block
cIvIcKILLA240style
I am trying to get myself into another project...if possible i would like the head to be as complete as possible...i think this is going to be moved...but thanks anyway...
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Since you are looking for a longblock, nothing else is required for you to be usefull. Try asking the people at Osakajdmmotors.com. They don't specifically list it, but just ask them about it.
I H8 UR DSM
ok, the old high port vs. low port design of the s13 an s14 heads, respectively.....
now has ANYone ever heard anyone trying to put a s13 head on a s14 block? or s15 block? Or maybe s14 block onto a s13 head, for the sake of running the s13 setup for it has no vtc...if anyone follows the question, lol?
ItzGenX
It sounds like it wouldn't work any better. The internal bottom end of the two are basically the same. Swapping heads would be like swapping changing the s14 into a s13. If I were to do it, it would only be to get that ugly hump off the valve cover and to get it red. :ylsuper
cIvIcKILLA240style
i am not trying to do anything crazy i just want an entire head from a S14.....somebody help me
I H8 UR DSM
ItzGenX wrote:It sounds like it wouldn't work any better. The internal bottom end of the two are basically the same. Swapping heads would be like swapping changing the s14 into a s13. If I were to do it, it would only be to get that ugly hump off the valve cover and to get it red. :ylsuper
'well my thinking was if you have an S14, you have the T28...and swapping a s13 head would give you the high port flow, therefore giveing more hp than the stock s14...no?? : ), so therefor the S14/s13 would have more hp than the S13 or the S14 alone....right?
just thinking
cIvIcKILLA240style
come on guys.....i JUST WANT A F00KING S14 HEAD.....not this wack discussion....
I H8 UR DSM
try phase2motortrend.com.....your best bet is to locate one from japan...
there is a s13 long block on ebay
cIvIcKILLA240style
alright just talked with wayne...he is searching for me.....any other places i can try
ItzGenX
You got a point there, but wouldnt it be cheaper to have a S13 motor and put on a T28? LOL.
cIvIcKILLA240style
I JUST WANT AN S14 HEAD.............i am not trying to make some WACK motor...just trying to find an S14 SR head
ItzGenX
You said you talked to wayne. Isn't that good enough? Have you talked to OsakaJDMMotors yet?
I H8 UR DSM
i mean really...how hard would it be to call all the places that import motors, there isnt THAT many of them....heavythrottle.com,jspec might get a long block, importintelligence.com, unstable, nipponmotors, blah blah
