Trying To Find Cumbustion Chamber CC's And Gasket Thickness etc...
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
iskone
First I should say hello. I own a few Z's and the VH45 might be going into one.
I've been lurking for a while but haven't found some of the info I would like to does anybody have the following?
Chamber ccGasket compressed heightQuench distancePiston to deck clearance
I want to build a NA motor so I want to up the compression and I've been following Defrag10's threads plus looking into other pistons/options myself but need more info.
ThanksIsk
iskone
Nobody knows???? Man, this a tough engine to find info on....
Isk
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Yeah I've wanted the gasket thickness dimension for a while now.
iskone
lol, thats too funny.
How is that cam stuff coming along? I'm about to go LS for my Z if I can't get any good info on the VH, lol
Isk
Mettler
Lol why settle for an inferior engine?
Cams are coming along alright m8, will have some results soon.
Why exactly do you need info on the VH? It's a kickass engine in standard form, and can be seriously hotted up.
tmorgan4
Car: 2000 Nissan Pathfinder
I've got a completely disassembled VH45 but I don't have any way to get measurements to do you any good. I'll see if I can borrow a set of calipers.
iskone
tmorgan4 wrote:I've got a completely disassembled VH45 but I don't have any way to get measurements to do you any good. I'll see if I can borrow a set of calipers.
Oh that would be killer. I don't know how far you wanna go but if you need some help with budget cc'n let me know. I cc'd the chambers on my E88 for like 5-10 bucks.
Isk
tmorgan4
What's the best way to go about measuring chamber volume? Why can't we go off of the 4494cc/8 cylinders to find volume?
iskone
Mettler wrote:Lol why settle for an inferior engine?
lol, that's all a matter of opinion.
I want the info so I can build up an engine on paper and get an idea of the power, I need that specific info so I can squeeze out the most compression and get an idea of max valve lift in case I need to run custom dome pistons. I'd like to get the CR into the 11-11.5 range and run a very large and aggressive cam, my car is very light so I can sacrifice bottom end torque.
I'd love to drop a cam(s) in and make 375-400hp at the crank. But from what I can tell that's it before I have to go with custom pistons and a big bore, then it's onto porting the heads/mani and larger injectors.
I'm looking into the the LS because it's a swap that has been done already, I can buy the mounts and headers for it, I don't have to convert my fuel system if I go with a ls carb conversion, I don't want to use ANY power adders, I can make more power with less r&d (less money), I can still spin to 7,000rpm, biggest plus is no damn ecu.... for me anyway.
When I stack the 2 up side by side for the INITIAL power level I want they look real close but there is alot more time that will go into the VH build when I want to upgrade and I don't want that. In the end the ls 6.0 will make more power in N/A trim with less work, it can go to 600hp for less then $5,000 with bot ons, one step at a time.
But then again I do love figuring all that **** out and getting it perfect, LOLHmmmmm maybe I'll have to sell off my L28 from my 72' to do some crazy VH build if I end up with the ls in my 71'
Isk
iskone
tmorgan4 wrote:What's the best way to go about measuring chamber volume? Why can't we go off of the 4494cc/8 cylinders to find volume?
When I say chamber volume I mean combustion chamber.
Okay, so i was lazy and just found a how to site... http://www.hydrostream.org/Art...s.htm The basic idea is to use a piece of plexiglass with a hole in it and seal it to the head with grease. Once that is done you fill the empty volume with a known amount of fluid and there you have the chamber volume. It's accurate within 1/2 a cc at least.
But I have done this a few times and it works real well. Only Instead of IPA I use Xylene (from when I was making my own high octane fuel) I also use a syringe instead of the burette, it was free from work. I've even done this to measure the dome of a piston, you could measure dish too.
Isk
defrag010
yeah, last year whenever I tore down a vh and measured everything I could, someone in the shop ran off with my head CC kit, otherwise I would have measured chamber cc. Going by looks, I'd assume it is around 40-45cc, but that's just a guess from judging it by size compared to other 4v heads that have similar chamber sizes.
I have a stock VH headgasket in front of me that I just measired with a 0-1 outside mic, and the firing ring comes to exactly .070" thick uncompressed, so I'd guess between .040 and .050" compressed.
iskone
Cool, it's funny because I was just guessing and came up with the same numbers when I punched them into my DCR calc. Still would prefer something solid but that sounds REAL close to me.
Isk
Return to “VH45DE / VK45DE / VK56DE Forum”
