jravensc »
https://forums.nicoclub.com/jravensc-u66439.html
Tue Jun 05, 2007 5:35 pm
I just wanted to give you guys a huge thanks. I replaced the sensor today and it was a NIGHTMARE. I consider myself descent at working on cars and I really could not have done it without you guys helping. If I had to 1-10 scale the difficulty I would have to put it at a 7.5.
So the diagram from cold zero got me started and the advice from 94 GXE was spot on. It is located in the back of the motor. And I'm talking about super tough to get at. I had to do the whole thing blind. No visual on the wiring harness(its a push tab..push towards the motor) to the sensor itself. 10mm bolt. You cant get the bolt out with the harness attached so I got that off, got the bolt out, then i had to put the harness back on to get a better grip and remove the sensor. I remind you this is all by feel.
I did want to post this info so others may be able to search it. But i would have to put a disclaimer. Unless their are some tricks to this that I was not aware of, this is a pretty hard job.
So anyway, replaced sensor, has a new spark plug, cleared all CEL codes. Now we wait.
Thanks again,Justin
