the voltage is fine.Silvia007 wrote:Have you checked the voltage at the battery when the car is on. Should be around 13.8 volts. Sounds like your alternator isn't working too well and your car is slowly draining your battery.
For your second problem, is your shifter shaking with your engine? I have a buddy with a bad driveshaft that as he starts out in first gear, it would shake rather violently and as it picks up speed, it would go away. Replaced driveshaft and no more.
oh sorry! my car is AT, but i was just making a wild guess with the clutch slipping. thank you for your informationemo_tactical9 wrote:Have you had your starter checked out? Could be that. My car shakes when i first take off, but i think it's cause of the ****ty clutch i got. You never mentioned what trans your car has, but you said clutch so i'm guessing manual. It could be about 20 different things. And the title of your thread is probably why no one is reading it.I'm not trying to be an ***, it's constructive critisim.
when i turn the head lights on the starter still clicks, and sometime it even starts with head light on. geez i think my car is getting a sense of humor on meShaunakaRichard wrote:From what you've described your battery is getting drawn on it constantly so your battery is going dead. Saying that the you can here the starter clicking, means low voltage or high resistance. Since you turn your lights on and your starter won't even click anymore, means its not getting enough juice. If it was a problem with the starter, it would repeat the same symptom regardless. If you have a tester take the positive lead off your battery, turn the tester onto ammeter setting, as in amps, put the red lead on the positive battery cable and the black lead on the positive battery post. If the tester reads anything with everything off in the car, then something is constantly drawing on the battery. So you'd have a short somewhere and its draining your battery so you don't have enough juice to turn the starter over, more technically to activate the solenoid on the starter.
actually, i have no idea. but hey, thanks for the info, now i learned something new.ShaunakaRichard wrote:Not exactly sure what the problem is now, but if you have an automatic transmission then that means you don't have a clutch. Wasn't sure if you picked up on that.
i just replaced those when i replaced MAF, distributor and spark plugs. I think i might need a little help on locating the starter, i am clueless where it is. =/dnlx5 wrote:i would guess your starting problem and your check engine light are not related. as far as the starting issue mebe a wire is loose somwhere go through and tighten all the connections. also tighten the starter to its mount because that is how it is grounded. also i completly agree with ShaunakaRichard who had a good point about seeing if theres a constant draw on the battery.
As far as the check engine light and vibration issue i would guess that your getting a misfire. you didnt mention any power loss but i guess nobody really pays attention to 1000 rpm power. but mebe get new wires see if that helps. i think it might be possible that your camshaft position sensor (or the wiring leading up to it) was feeding bad signals to to the ecu and ( mebe there only kinda bad) and the ecu sends kinda bad signals (too much fuel too little fuell bad timing advance) at around 1000 rpm where a misfire is caused really just throwin that out there pleease post up when you find out what it was im curious
the car has a clean history I carfaxed it before i bought it. car has 130k+ miles. no clue about the torque converter. where it is located? what does it look like?the engine doesn't shake at all when it is idling.The plug wires are new.hope this will clearifygot_chub wrote:if you alt. is not working right when you take off you positive terminal to you battery the car will either die or die a few mins later from no power being made.
do you know the history of you car? how many miles? when last time torque converter was replaced if ever? they do not need to be replaced that often but it could be worn out. I'm not sure if you can get flywheel chatter in an AT but manuals can
check you motor mounts they might be worn also. my car shakes like a old skol v8 when i start it but that's all.
any auto part store will have a tester for the plug wires, lights up every time it sparks
the more detailed you are the better we can help.
