Trying to figure out this wheel fitment...
LaMaR-
Car: 91 Coupe
IDK much about wheel fitment, but trying to learn offsets and stuff..
Stock S13 coupe Dropped on Coils...Was thinking about going with 30mm rear overs but might wanna go with 50mm if these wheels would fit.
Specs are
18x9+28 18x11+18 what would I need to make them fit?
Nali
Car: Datsun Nissan 280ZX
http://marksink.com/tire_wheel_offset/o ... ulator.asp
Use the offset calculator.Itll tell you how much the new wheels will stick out.
P.S Can a mod put the offset calculator in the Ultimate sticky cuz i think its gonna help a bunch of noobs in the future.
S14toRPS13
Just looking at those numbers I can tell you you're not even close to being flushed with a 50mm overfender. Try a negative offset and use the wheel offset calculator.
fourLUG_hero
Just from looking at the sizes:
Front's will rub coilovers without at least a 8-10mm spacer.Rears will fit under stock body with a slight pull, stretched tire, and a few degrees of negative camber.
simmode1
Car: Red '95 S14
fourLUG_hero wrote:Just from looking at the sizes:
You don't need widebody to fit those. They'll fit under stock fenders just fine.
As for spacers, 5-7mm is the safety limit for slip-on spacers on stock studs. Past that and you'll want hubcentric bolt-on spacers. With 18x9+28, you might be able to make them fit with a 7mm slip-on spacer, but it'll be close...
240lookis
Car: 1990 240sx hatch
i would get a 15mm bolt on spacer for the fronts making the wheels clear and be more flush.id test mount the 11's and see how much poke there is with your current alignment. what size tire do you want to run and how much camber do you want to run? based on that, we can figure out if you need 30mm overs or not.
AZ89two4Tsx
11's under a stock fender! LOL!
Yeah right, unless you want it to look like garbage.
AZ89two4Tsx
Here's an 18x12 -5 with a MASSIVE pull and a big tire stretch.
Your 18x11s will stick out about an inch less, which is STILL sticking out from that fender pull. Are you really sure you want something like that?
Here's the link to that dude's thread:zer...age=1
240lookis
dude 11s in the back are totally doable with work.ive seen a bunch of people fit 18x10.5 +15 te's in the back with a roll and slight pull and 245/40. if you did 245/35 and got a fender roller to do a nice pull, you could fit the 11s out back with -3 camber.
EDIT: and to az89 - those 12 -5 will stick out 36mm more than the 11 +18. get your facts straight.
simmode1
Car: Red '95 S14
240lookis wrote:EDIT: and to az89 - those 12 -5 will stick out 36mm more than the 11 +18. get your facts straight.
18x11+18 will poke out about as much as Enkei RPF1 18x10.5+18, but it will be .5 inches closer to the rear suspension. No problems here, just modest rolling/pulling/camber needed.
18x10.5+17
18x11+10
AZ89two4Tsx
Okay, I'm sorry, 1.4 inches. Still would look horrible with a pulled stock fender. Not to mention stupid as you'd have to run a very stretched tire, also stupid. And who the hell would put a 245 on a 10.5" wide wheel? Retard.
Wow, that looks really stupid.
Gabes13
Car: rb20det s13
18x11+18 would be sunken w/ 50mm overs
fourLUG_hero
[img]http://www.rimtuck.com/photos/1257672868.jpg[/img
AZ, don't turn this into an anti-stretch argument.
My two cents: I'm putting a 225 on a 10" if it makes anyone's butthole sore.
simmode1
Car: Red '95 S14
AZ89two4Tsx wrote:Wow, that looks really stupid.
Many ppl would disagree with you. Besides, the purpose of the pic was to display the amount of poke the OP would be dealing with, not to advocate tire stretching or not. That car has -2 degree of negative camber, which isn't too bad.
If you want to run wider tires, you'll want to pull the fenders more, like in the other pic I showed.
AZ89two4Tsx
THIS. I understand people like form over function, but come on, at least have the tires KINDA fit.
Sorry for stating my opinion, you're right this isn't a debate on looks. /rant from me
simmode1
Car: Red '95 S14
I totally get ya. I'm not a fan of big stretches either, but I understand its appeal and purpose. I just wanted the OP to have a good idea of what he's in for...
neverlift
lol I had to pull my fenders for 225 55 16 16x7+12(no pics)
you can fit fairly low offset wheels under stock fenders all day. 195 60 15 on 15x8-42 check sig and go into the buy my wheels link for pics
KC240SR
Car: 92 coupe w/ blacktop SR
I like how AZ is talking s*** on these cars that have amazing fitment and his wheels look like some FWD offset cheapies.
redhb240SXS13
Car: 1992 240sx Coupe and 1995 240sx
Pretty sure AZ's wheels are SSR MS-1's, not exactly what i would call cheap.
AZ89two4Tsx
KC240SR wrote:I like how AZ is talking s*** on these cars that have amazing fitment and his wheels look like some FWD offset cheapies.
Were you reffering to the pic of where my car was wrecked? Cause the fender bent outward, thus giving my wheels the "sunken" look.
Lets see some pics of your car hot stuff!
Gabes13
Car: rb20det s13
You know AZ, I've probably clicked on your "if you like turtles" link in your sig 5 times.....
And I always forget it just kicks you off.
Nali
pandapants wrote:You know AZ, I've probably clicked on your "if you like turtles" link in your sig 5 times.....
Are people still falling for that?But wait wait wait.....you like turtles?
