Trying to figure out an odd rattle.
Mrcjolsen
Car: 2011 Nissan Rogue S AWD
It sounds as if it's from the forward part of the center console. Seems to be from inside the cabin, and not the engine compartment.
Starts at around 60 mph.
Very random - not timed or in sync with any mechanical or rotational aspect of driving.
Independent of any components - fan, AC, stereo, - that may be running. I've turned them all off and it still goes.
Sometimes it seems to go along with the car going over bumps, but happens on perfectly smooth roads as well.
One way to describe it might be as if there was something small flying around inside a close space, trying to get out.
I also thought maybe something loose or dangling near the rear of the engine compartment that was knocking against the firewall at speed due to wind effect.
I tried removing the cabin air filter and vacuuming out that area, but it didn't stop the rattle (but I removed a ton of crap and dust from the filter area)
If I can be assured that it's not anything mechanical, I can live with it (it's not very loud, you really need to turn off the stereo and turn down the fan in order to hear it)
Thanks,
ROGUEPLANET
Car: 2012 Nissan Rogue se
I had a rattle that was driving me crazy for the first 3 months i had my car. I took it in and the dealership went through and clipped and tightened and foamed tubes in the engine compartment.
Sound went away.
Its in the road noise part of your warranty, or something like that.
Dealer should troubleshoot it and take care of it for you.
They didn't tell me exactly what, but the two air conditioning tubes were probably the problem because those were the ones that were strapped the most.
Also sometime the seat belts will rattle on the sides and make you think they are coming from somewhere else.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
Return to “Rogue Forum”
