See, that's where it gets interesting.
Those numbers are for an S13 or S14.
Now, you wouldn't think they'd vary much from car to car, in essence meaning that the H&Rs are generally slightly stiffer than the Sportlines. However, I have found one other page with this sort of info, but it refers to VW Golfs/Jettas, which are more similar to my car in terms of vehicle type and what you ought to do to get the most of the car.
Here's the link -
http://forums.vwvortex.com/zerothread?id=602321 (numbers are in lbs)
Suddenly, for the life of me I can't find the specific numbers in there for the lazy. I'll keep looking and edit when I find them.
Basically, the fronts match up (about) with those numbers you showed on the S13 in the sense that the Sportlines are slightly softer. However, the rears on the Sportlines are a good bit stiffer. I figure that's to combat understeer.
For the life of me I can't find numbers for any B15 - QG, QR, or SR powered.
Oh, and the drop is different. the H&Rs supposedly get 1.5F 1.4R (I think it's closer to 1.4/1.3) and the Sportlines supposedly get the same 1.5/1.4, although I think that number is a little off as well (the car actually being lower by a tenth or so).
edit: Here's some BMW numbers I found last night -
http://e30m3performance.com/in...2.htm - I'd think that, being a sedan, that'd be slightly closer but hell if I know.
It says: H&R Sport - 185F/380REibach Sportline - 160F/455R
I know that the yellows are really the key part to the suspension, but I'd like to get the springs right too. Every ricer around here runs Eibachs, usually Sportlines for the drop, not the better numbers. I really wanted to be different, but if the numbers tell me otherwise, and since the Eibachs are (slightly) cheaper (probably because they sell many, many more), well.
Modified by nametakennow at 12:15 PM 1/16/2005
