VVT is not like Vtec lol. Nissans VVL is like VTEC. And costing more upfront and less later??? With the RB it's going to cost more all the time. The 20 get you in a little cheaper but mods still suck for either 20/25/26. You sound like your on a budget so I'll say go with the SR20. Parts are every are cheaper than the RB motors. If you want something different I suggest that you go looking into the Neo VVL head swap for the SR20's. Thats Vtec for you, not like that S15's either thats not "Vtec" either.jrd450r wrote:they are the "NEO" motors with VVT, variable valve technology, kinda like v-tec. So if the RB20 price is catching your eye its becuase its for a reason, in the end your better off going with the 25 IMO. Its more money upfront but less in the end.
My bad with the vvt/vvl, VVL is what i ment, thats why i said it was like vtec. And the fact of the costing more up front, im saying that if he wants 300-350hp eventually, it is cheaper to achieve those numbers with the RB25 than with the RB20 since the RB20 may require bottem end work and new pistons and everything else that needs to be upgraded to handle that power. Sorry I understand it was kind of a confusing post but its true.Yellow4g63 wrote:VVT is not like Vtec lol. Nissans VVL is like VTEC. And costing more upfront and less later??? With the RB it's going to cost more all the time. The 20 get you in a little cheaper but mods still suck for either 20/25/26. You sound like your on a budget so I'll say go with the SR20. Parts are every are cheaper than the RB motors. If you want something different I suggest that you go looking into the Neo VVL head swap for the SR20's. Thats Vtec for you, not like that S15's either thats not "Vtec" either.
Miss info again. RB25DET's have the VVT which is just cam timing on the intake. VVL is more like the Honda Vtec, the cams have 3 lobes per rocker arm. Not sure why you think the RB20 can't do 300-350hp with out internal work either? My daily driver is a NX2000 with a SR20VE lol thats why I know so much about VVL.jrd450r wrote:
Yellow4g63 wrote: VVL cam non VVL cam as in the RB20/25/26.
Ohh I should post track times. I ran a 13.7@99mph in my RB20 hatchback. Mods were 3" downpipe/nocat/3"exhaust, Filter, boost to 12psi 1st to 2nd gear then 10psi the rest of the way. 255lph pump, Stock sideheater, J30lsd and base map RB20 PFC.http://www.3rdgearvtec.net/And...k.wmv Old crappy vid. Never went back to the track after the FMIC and intakemanifold someone hit my S13 before then and I have been on the lazy path to getting my S14 running. That damn VVL NX2000 is taking up alot of my time.
IIRC you can use the same mounts, but requires a r32 xmember swap.RB20s13coupe wrote:I've read in the sticky posts on this thread that the RB20 will bolt up to the stock KA mounts and driveshaft? is that a typo?
Carl H wrote:as i said in another thread t3/t4 57trim + injector + z32 maf + 16-18psi = 300-350whp.
ownedKamin wrote:way to bring back a 5 month old thread
hmmmm......u talkin about the 20 or 25 carl?Carl H wrote:as i said in another thread t3/t4 57trim + injector + z32 maf + 16-18psi = 300-350whp.
