Trying to correct -Front Camber! `95 s14
goodsx95
Car: 1993 nissan 240sx
I've grown tired of replacing my front tires all the time and can never seem to find an answer to my neg front camber!I'm running megan racing coilovers and have adjusted the upper pillowball mount to give me the most postive camber it will allow. The hex bolts in a recessed slot don't allow much movement. Don't know if it's a poor design or what, but now I'm running about -3 degrees. I just got 4 new tires, and I'd like to keep them for more than 6 months! I was wondering if there are any eccentric bolts out there for the UPPER and LOWER part of the nuckle, thinking maybe if I adjust the lower to pull in and the upper to push out I might get more correction than the little 1.5 degree kits I've seen running around.
Any help would be great. Courtesy Nissan couldn't recommend anything for an s14.
-Mike
Rucca
Find a shop that will grind out the upper mounts for the coilovers so they are slotted as well.
It sounds like maybe you have something bent, though. I'm running Megan Tracks on my S13 with the camber all the way negative and it is, I believe, -2.0?
