trying to buy a 411 sss :)
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
2002jm
Car: 411 sss
Hi! New to this forum. Trying to buy my first Datsun 411 sss. It is in the desert in Nevada and has no title or registration papers. Been there for 15 years! Anyone know how I could get this thing registered, and get a title?
Thanks for any help,
jm
Reason: Duplicate topic deleted
Are you in Nevada? If so, find out the process for an abandoned title application in your state.
Good luck - I have a 67 SSS wagon, they're super-cool!
2002jm
Car: 411 sss
Thanks for the reply. The car is in Nevada l am in ldaho. Jm
MikeRL411
Car: 1997 Infiniti J30T
1967 Datsun RL411
Make sure the SSS unique parts haven't been stripped, they are expensive and hard to find. There were only about 4400 total RL411 imported to North America, so after 53 years not too many survive. More wagons than sedans were imported so they add to the small population.
Engines are not directly interchangeable with roadsters and require modification to fit into the tiny engine compartment.
2002jm
Car: 411 sss
thanks for the reply and information. As far as I can see all the parts are there except the front grill and badge; bet that is going to be hard to find! If I can't get a title, this car will not work for me; just too much money to put into a car that can't be driven.
Where does everyone get parts for the 411; like interior parts?
thanks,
jm
MikeRL411
1967 Datsun RL411
Not all RL411 have the SSS front badge. Mine has a "1600" badge. Look on your trunk lid for the "Datsun1600" badge. If it is there, you had the "1600" front grill badge. If you have a SSS trunk badge, look for a SSS grill badge. Some 520 or 521 front grills MAY be modified to fit the 411. It takes ingenuity to keep these cars rolling. Headlight chrome surrounds may be sourced from other Datsun trucks, or in the extreme I think you could modify early Corvair or Chevy two van surrounds. The screw holes will not exactly line up but they will be 20 foot away acceptable.
Interior parts? Depends on what you need. Upholstery is a do it yourself or pay a shop. Carpet is after market kits [although it seems quality has tanked in these]. Instrument gauge panel, use 520 or 521 units. Roof panel ? Good luck ! Seat belts, use RV after market kits and trim the length to fit. You will probably not find matching to original buckles, so be sure they are at least consistent with each other.
Good luck with your purchase !
2002jm
Car: 411 sss
Thanks again; good to learn as much as possible about these cars. Now to see I can get a title worked out:)
jm
Return to “Datsun Chat”
