klattr1 wrote:ask him what size head studs/bolts he was using...
as far as the stock vs metal HG thing goes, if you plan on surpassing on 400 whp and 20+ psi, then go with the Cometic HP headgasket...the stock headgasket can work at that level, but it takes more octane, better tuning, etc...all it takes is for the head to lift a little and destroy it...
but on the same note, about the "fuse" issue...i usually tell people to go with the Cometic if they are confident in their tune...if the tune is too much on the edge and/or octane used, etc, then it could damage the bottom end sooner than compared with the stock HG...
I'll ask him, but I'm betting they weren't larger than 11mm.
I really don't want to run more than 20psi boost (but you know how that goes...starts with 250whp...next thing ya' know, you're at 300whp...and so on, and so forth ).
I really have a hard time believing that the head will lift on 20psi using 10mm headstuds. That's a substantial increase in clamping force, plus the lower static CR MUST help with peak cylinder pressures (when compared to say, a 9.5:1 CR), or no one would bother using low comp. pistons.
As for the tune, I plan to make it like the perfect female...really rich and pretty retarded. No, seriously, I'll do it by the book...start with AFR's in the 11.5:1 range and timing pulled further than necessary and work my way up until I reach MBT...then back everything off just a tad for safety.
Thanks again for all the help on this. It's great to have such a vast knowledge base here at our disposal. I hope I can give back as much as I've received on this forum. Whatever my final decision, I'll be sure to keep everyone updated as to the progress of the project.
Cheers!
