try to figure this out
Mudvayne
Car: 91 Nissan 240SX
93 Nissan 300ZX
81 Chevy El Camino 496 stroker
i recently just got my car to start finally. but it started with the fuel pump off it sputors with the fuel pump on so i take the fuel pump off and it starts for a little bit. does a stock ka24de need a fuel regulator. how do u know fuel injectors work.
Modified by Mudvayne at 5:38 PM 2/9/2008
Modified by Mudvayne at 6:01 PM 2/9/2008
TheRipper
Car: 93 Nissan 240sx SE R.I.P. & 90 Nissan 240sx
Check em and see if they are spraying out fuel
Mudvayne
93 Nissan 300ZX
do i just turn them over and turn the car on
S13 240SX
Car: 93 Mazda Miata
dude all u gotta do is have someone turn the key to "ON" and stand at the rear and hear if the fuel pump comes on, if you hear it making a noise its good.
fuel inejctors, again just turn the key have someone do it, and listen to each 1 one by 1 by ear with a screwdriver to your ear. if you hear injectors click they should be good to go.
cjshesko
Car: 1993 240sx coupe SE, KA24DE
S13 240SX wrote:dude all u gotta do is have someone turn the key to "ON" and stand at the rear and hear if the fuel pump comes on, if you hear it making a noise its good.
..but what if there's a problem (like a clog/leak) in the line, closer to the engine?? you would hear them come on but fuel flow would still be disrupted.
did you try injector cleaner.. like seafoam or anything? that along with checking the lines (with your eyes) would help to narrow your search for the problem.
and yes, I believe a Ka needs a fuel regulator. That is the kind of thing you upgrade when you can, not remove altogether.
and lastly, did you check your spark plugs? it is possible for them to be dirty enough to make the car sputter and seem like it is choking... just a thought..
Mudvayne
93 Nissan 300ZX
it keeps burning the plugs. i have 2 injector wires that r striped were it conects to the injectors. when i press the gas it dosent rev up at all
Vegascorbin
Car: 1990 240sx dirt track race car
Yes you need a Fuel Pressure Regulator. The stock unit is located in the Fuel Return line at the rear of the Fuel Rail. It runs off of Vacum.
When was the last time you changed your fuel filter? It sounds like a cloged / blocked fuel line to me.
Change your fuel filter, fix the bad wires and check again.
cjshesko
hehe stripped wires?? You shouldn't have even turned the key until fixing that..
safety first
