kind of late but.
Is it do able yes, but its not practical, as stated above you would be putting a solid lifter cam onto a hydro lifter. The lobe ramp is designed diffrently for the solid and hydro lifters.
And you only gain little bit of lift and some duration and IIRC Ex duration on GTR is less than that of Rb20(but that's from the top of my head).
You would need GTR32 cams, (adj cam gears are not necessary to get it running) but to get the optimal performance. You would IIRC need to retard intake about 2degrees and advance exhaust dont remember how many degrees, this is where adj cam gears come in handy.
There is a Ausi forum that people talked about it. Some broke/bent valves. So I'm not sure if this truly works.
I have a set of R32 cams In, Ex, that I was going to put into my RB20.
And you can buy solid lifters their only about $450, and GTR cams you can pick up for around $200 for set. And adj cam gears cost usually $280+/- depending on brand.
This is a video from that Aussi forum that someone posted, somwhere in USA(Missouri?) 240sx with Rb20 and Rb26dett cams think he was running Hyro lifters and non adj gears. Anyway it was while back when I was looking at it, but I went a different route.
http://www.youtube.com/watch?v=VQW1AAPi4tc
GL
