RobDET »
https://forums.nicoclub.com/robdet-u7114.html
Wed May 26, 2004 4:50 pm
First, I have heard the question a couple times and i want to provide yet another "I have personally done it with my own hands" answer to the question of will KA internals go into the SR case. The answer is Absolutely. With no problems at all.
Second we have had some threads on this recently and the internals of the transmission are similar but are NOT identical. The gears, syncros, bearings exc are however the SR has some kind of extra contraption on the shift rod. Looks like it locks out reverse or something. I did not use it on my KA transmission and everything is fine.
Also. Everyone warned not to get an unsprung puck clutch be casue it's not streetable. I've driven it a couple times now and it's really not a big deal at all. If you have some skill with a 5spd slipping the thing is not a problem. I also REALLY like the increased pedal effort because the stock (SPEC II) pressure plate is SO soft I always felt like it was slipping too much. I will admit however that in a hilly area the HDR6 is probibly not a good clutch but if you live where it's flat (Mississippi) it's great!
