VG30DE wrote:The key has never worked. Just doesn't turn.
I tried turning with a pretty good amount of force, but don't want to break the key in there.
Any ideas?
I can't get in m trunk at all, I have 2-3 24 packs of water, my wallet, etc.
This sucks!
If the key has never worked, but the trunk once opened using the electronic fob or the door mounted switch, I'd first suggest obtaining a good key. Is your's an original titanium key? Once inside the problem might be the small electric motor driven gear mechanism that opens the latch when activated, and then springs back. Your's may be jammed or broken.
Mine used to stick in the open position (the trunk lid wouldn't latch), until I opened it up and removed a few gear teeth on one side so it wouldn't over-rotate. I still open the trunk using a key, instead of popping it with an electric switch.
More recently I had a similar thing happen with the fuel door latch motor/gear mechanism. It took some inside expoxy work to fix that.
