Q451990 wrote:Did you check the kill switch in the glove compartment ? Heath
Hey David- If it turns out to be the kill switch don't let us know. Just say a wire was loose on the kill switch connector.
It sounds like the key works but not the door button? I'm not sure if your 93 has a remote fob and if it works the trunk but the trunk lock actuator is easy to access and remove. After checking the kill switch connection ( ), if you suspect it's the actuator you can remove it, jumper to a battery, and see if it works. It's a 2 pin connector so you can easily check for 12v with a meter while someone depresses the door button. Good luck.
