hendric5 wrote:I doubt its contacting the firewall as I wend through a very thick stock grommet. I didn't know if the remote amp on wire could have been miswired but since the radio was not on (I tapped in to the switched 12V wire supplying power to radio - maybe bad idea?). I'll have to sleep on it tonight and maybe it'll come to me in a dream. Thanks again for your help and advice!
I think your radio power wire is the problem. My buddy did an install where he thought he was using switchable radio power for his remote on wire. Instead the 12V wire was always on or something and his subs would just play loud distortion. I know this seems unlikely but I wonder if that could have over loaded the amp and pulled too much current?
You could check by disconnecting the remote wire, replacing the main fuse, turning on radio, and then connecting the remote to see what happens.
