trunk stays
haggisgood
Car: 2002 Infiniti Q45
Thanks to everyone for answering the accelerator update question.
My '02 Q has the optional spoiler and since I just bought it used, the stays (struts) are not holding up the trunk.. Obviously due to use and the added weight?...Dealer wants $150 a piece for each "strut/stay".. and $300 for installation. Total = $600.reason for expense is having to remove the rear seats to access the struts.. These seats are heated/reclining (premium pkg) and I think I am taking a small chance w/ dealer properly putting the back seats together. Seems once something is taken apart.. its never replaced exactly the same way.. even w/ a dealership.Anyone have a suggestion on how to proceed here?$600 seems a bit steep for something thats used maybe 1 time per month.. however the trunk will drop w/ major force which will probably kill my rear camera and maybe take a hand off in the process!Thank youHaggis
Q45tech
Mods always cost more than the simple purchase price! The law of unintended consequences.
Q451990
I think you're right that it's definitely something that you want to fix. It's bound to break something at some point if it's slamming shut too hard.
If you're handy, I would lean toward buying the stays from IOS http://www.everythinginfiniti.com and doing the work yourself. The "lift cylinders" as they're called on the site, are about $187+ shipping, but they only show one style, so I'm not sure if they would be stronger than the ones that are already on your car.
Remember that the only way a dealership tech. can make $$$ is to beat the clock by doing the work in less than the book time you're paying. On the other hand, you can take a full weekend to make sure it's perfect if you want.
The FSM is available at http://www.phatg20.net and should be pretty detailed on the correct method of removing the rear seat.
Good luck!
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check with member jasonb for his high assist struts.
http://www.burtmanindustries.com
Modified by maxnix at 10:38 PM 6/28/2008
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
haggisgood, I wouldn't try this yourself unless your very good. Taking out the back seat is not for folks that don't DIY all the time. It will end up taking you way to long.
Have you tried the independent Infiniti shop in San Diego (I noticed you were there). I have never done anything with him but many NICO'ers rave about Jerry Tucker in San Diego. Maybe he can knock the labor job down a bit...I doubt you will find anything 3rd party to fit this.
FYI, all Nissan hydralic lifts fail, that was pretty fast for yours. My Z's failed and the Nissan ones were really pricey, even with simple install. I did find good quality aftermarket ones for 1/2 the price...My rear ones also failed and I again found aftermarket ones that were 1/2...and they have both already lasted longer than stock.
haggisgood
thanks for the info.. do you know what is the name of the independent Ininiti store in San Diego?..thanks again.Haggis
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Shop. http://www.jerrytucker.net
Our guy is Joe and the crew
http://www.infinitipartsusa.com
Do look at jasonb though a his are strong enough to lift the trunk completely and if your spoiler is heavier than the itty bitty stock trunk lip......
mcrews
Car: 2002 Q45 Sport
haggisgood wrote:Thanks to everyone for answering the accelerator update question.
Haggis,I am a so so mechanic.I installed the burtman high pressure units myself.NO you dont have to remove the rear seat.U can get to the small clips w/ a long screw driver.
The job is easy and not even a "knukle scrapper"
Send me a pm and I'll walk u thru it.
Jason B
Car: Infiniti Q45
Here is the ORDER LINK for the trunk struts.
http://www.burtmanindustries.c...k_kit
I also have them 02+ Q45, and 03-04 M45 on the site,
Jason B
Car: Infiniti Q45
I just got a fresh supply of these made. I've had a few asking about them and all these posts are old. Yes, it pops the trunk FULLY OPEN automated, by itself when you hit the trunk button on your remote, etc.
http://www.burtmanindustries.com/zoompr ... _trunk_kit
There is also a video of each on each link.
Q451990
:welcome: back!
boag
Car: 2004 350z & 2004 q45
this may be a little late but do you still have the info for replacing the stays without removing the rear seat?
HollywoodJackson
Car: 2004 Infiniti G35
1990 Nissan 240SX Hatchback
1990 Nissan 240SX Coupe
boag wrote:
Wed Apr 11, 2018 6:06 pm
I read somewhere that you CAN replace the stays without removing the back seats. You just have to reach in there where they are from the trunk side. They seem to be pretty far up in there. If you don't have huge hands, you might be able to do it.
I'm thinking about giving it a try myself.
All the best,
~HollywoodJackson~
