MajorPain wrote:We were going through a similar evaluation process to others here, and came down to the BMW 335i and the G37. Trunk space, limited though it was on the BMW, was one factor where it had a minor advantage. After we discovered the spare tire space in the G37, that advantage pretty much evaporated for the BMW. Subjectively, the BMW 3 series convertible trunk space looks about the same as the G37 spare tire space. The only remaining advantage to the BMW is that this small area is accessible, to a degree, with the top down.
If trunk space is critical, the only hard top convertible I am familliar with that has a relatively decent amount is the MX-5 Miata.
Right, but comparing the miata to a car of this class makes no sense.
Sure I can store more in a miata trunk with the top down than I can in an infiniti, but with the Miata, I've got only room for 1 passenger. In the infiniti, I'll likely only have one passenger, and I can use the entire back seat as trunk space. I've gotta imagine the back seat space in the infiniti is larger than the top-down trunk space in a miata.
Put another way, I'm driving to St. Louis with my son in June. I'll use the spare tire space in the infiniti for some storage, but the back seat for everything else. I really doubt we'll be hurting for storage on this trip.
Yes, it helps if you have a wind deflector to cover the backseat, but I don't think that's critical.
