trunk release problem
jmaggioc
Car: 1994 nissan 240sx
Anyone out there have a problem when they try to open the trunk from the inside lever? Mine doesn't seem to open the latch.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
mine does the same thing, i cant quite figure it out
94_240sx
Car: 94_240SX
It's because of bad struts. Eveyone's fixed it by replacing the struts.
zerothread?id=80918
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
is it moving the latch? if so then yea its the struts. if not then theres something wrong with the linkage.
biggie
Or someone at sometime has moved the release mechanism to 'valet' mode. If you look at the latch inside the trunk there is a piece that will slide up and down, when down it will not release with the lever, has to be in the 'up' position.
94_240sx
Car: 94_240SX
biggie wrote:Or someone at sometime has moved the release mechanism to 'valet' mode. If you look at the latch inside the trunk there is a piece that will slide up and down, when down it will not release with the lever, has to be in the 'up' position.
Oh! I forgot about this.
jmaggioc
Thanks. Alll you guys have been a great help! I'll try the "valet" switch tonight.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
Also, grease the release mechanism inside the trunk. Mine didn't work right until I replaced the struts and greased it up.
240zac
Car: 1994 240sx sr swapped convertible
My trunk will not pop open on its own when I pull the interieor lever, but if I pull on the lever and have someone pull on the trunk it will open.
That sounds like bad trunk struts to me ( at times i have to hold the trunk open too )
Where can i get these at and estimate on cost?
thanks for any help!
ishkabibble
1997 Infiniti I30t
Look up ^
94_240sx
Car: 94_240SX
240zac,Check this thread.
zerothread/320493
240zac
Thanks,those struts are MUCH cheaper than i expected!
94_240sx
Car: 94_240SX
OEM sturut is $171.47 listed for each. Part numbers are:
R: K6658-6X001L: K6659-6X001
I love OEM parts, but this is just too much.
Modified by 94_240sx at 2:37 AM 3/12/2008
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
$35 bucks a piece at local Vatozone. Bring a screwdriver with you to pop them on easy and make sure they work.
nihits
Car: Nissan 240 SX SE Conv
94_240sx wrote:OEM sturut is $171.47 listed for each. Part numbers are:
That is for the Hinge. Following are the details of the Struts
Its not really that expensive.
MISCELLANEOUS > CONVERTIBLE INTERIOR & EXTERIOR >
GAS STRUT ASSY-DECK LID
240SX 12/1991 to Present
Part Code: K3185
Part Number: K3185-6X001
MSRP: $63.40
Online Price: $46.60
94_240sx
Car: 94_240SX
Part Code: K3185
MSRP: $63.40
Thanks for the correction. Courtesy Nissan catalog says it's no longer available, but I will see if I can buy them. I can't stand aftermarket ones because I have been replacing them every year. They don't last long.
94_240sx
Car: 94_240SX
K3185-6X001 is No longer available. Just checked with Courtesy Nissan.
