Trunk release on rear bumper?????
Nissan 350z / Nissan 370z general community discussion forum
evoviiijeremy
First off I cant believe there is no trunk release in the cab of the car. But anyways my button on the rear doesnt work. Do you guys know which fuse runs the switch or relay? Anyhelp would be great.
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
Bump, you sure you have no release inside the car?
xjmxstac
Car: 2003 nissan 350z track edition
there isn't one in the cab that I know of... key fob or trunk that's it.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
snwbrdr435 wrote:Bump, you sure you have no release inside the car?
You don't need to bump a thread that was created the day before, this isn't Gen Chat - threads don't drop off so quick here.
As XJM said, there's no release inside the cabin. Key fob or rubber button under the deck lid are the only choices.
xjmxstac
I Would almost assume that it it's just a open circuit on the actual switch(under the lid). If it was a blown fuse, it will not work altogether. Check the wiring on the rubber switch under the lid.
evoviiijeremy
It was not me that bumped it. It was someone else. Chill.
But i will check the switch later this week. Also is there an online 350z manual somewhere? Maybe some PDF file.
BusyBadger
'05 Nissan 350Z
'13 Nissan Juke
evoviiijeremy wrote:It was not me that bumped it. It was someone else. Chill.
Thanks for clearing that up for me.
evoviiijeremy wrote:But i will check the switch later this week. Also is there an online 350z manual somewhere? Maybe some PDF file.
Here. Let us know what you find out.
ZMEDIC13
There is no release within easy reach from the driver seat, but there should be a release under the rear strut brace. If you feel under it there should be a rectangular cut out and there should be a small metal pull tab. It doesn't take much pull to release the hatch. It's in there because all cars have to have a pull release in case someone gets locked in the trunk/hatch. In cars with actual trunks the release glows in the dark or is supposed to.
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Oh, cool, that's good to know, I've been attaching/detaching the battery terminal to gain access to the hatch on one I've been working on for a while.
Thanks for the tip!
evoviiijeremy
ok I checked all the fuses and all is good. I appears the trigger on the rear bumper is plugged in. So I think the switch is just bad.
Dont know if I mentioned it but the trunk does open with the remote and I am aware if the release under the strut tower. Just want the button on the rear bumper to work.
thanks
xjmxstac
If you know how to use a multimeter, check the switch for continuity (in ohms).
Return to “350z / 370z Discussion”
