Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Oct 24, 2007 5:04 am
If tweaking the "flapper" doesn't work, you will probably need to replace the trunk release solenoid. Just seeing movement doesn't mean it works... I actually took the bad one apart and fixed it for a couple of cycles, but then it slipped again - so your description of it not being strong enough to work is absolutely correct.
Strangely enough, this part failed on Q2 at about 55K, while Q1's was going strong at 200K. Guess what got swapped before I sold Q1 after the wreck
Heath
