Trunk rattling...
ILikeMy240sx
Car: SR Power
My trunk is rattling when there is a slight vibration... Is there any way to make the trunk close tighter?
navysnail
adjust the latch
CiPHeR_Tx
i got the same problem on my HB...car was rear-ended...latch won't adjust any further
kamikazestorm420
how do u adjust the latch?
GEO
Car: 95 240sx KA-T
true, how do yuo adjust the latch.
navysnail
there are screws that you loosten, then you can slide it up and down
edit: ill see if i can uncover the old fsm tonight and check it out to give an exact procedure
CiPHeR_Tx
2 screws....loosen them...move the latch down....tighten screws...check for proper operation...repeat as necessary
hotshot240sx
Car: my 240sx
and if that dont work...the clip that actually locks the hatch down...maybe loose...and you would therefore have to replace the lock assembly...it took me 2 years to figure it out... i hope this will help you!
KRUZNBY
Car: 95 240SX SE
My trunk rattles too. I just have not taken the time to try to figure out what is wrong. It seems tight when I close it but still rattles. I did notice one of the rubber 'stoppers' on the lid is missing, so maybe that is the problem.
