Trunk Problems..
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
newbiezz
Car: 2008 Infiniti EX35
hi guys,
does anyone else have a problem when they close the trunk door? for me it seems like i have to slam it for it to close properly?
inteller
Car: 2008 EX35 Journey AWD
yes, you do have to give it a good whack to get it to close. Nothing wrong there.
sluday
Car: 2008 EX35 AWD Journey Moonlight-nav-premium-tech-lux
It has to do with interior air pressure. I had an Audi TT coupe and when you opened either door the window would go done a little so when you close the door the air could escape and make closing the door easier. If you have a window or door open on your EX you will notice a big difference when closing the trunk. Less expensive vehicles close easier because they are not as airtight as the more expensive cars. It shows how airtight you new truck is so be happy when you need a little extra effort to close.
Mark Booth
No problems with the "trunk" door on my EX35 because my EX35 doesn't have a trunk door!
(My EX35's hatchback door is sometimes a bit tough to close if I don't slam it hard enough though!)
Mark
newbiezz
Lmao
rubystar88
Car: EX 35
I had an issue with mine at first...until I made adjustments to a piece of plastic molding- Make sure that the plastic "guard" that sits over the "clasping hook", isn't getting in the way of the door closing.
newbiezz
Hi, I thought that yeah maybe it was that part that was causing the problems...what did u use to get it out of the way? Duct Tape?
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
