pits200 »
https://forums.nicoclub.com/pits200-u65914.html
Mon May 31, 2010 4:38 am
Ive reset the ECU multiple times by doing the gas peddle trick and still no luck.. Let me give you a brief rundown.
I installed the MP3 jack thing in the back of the radio satellite connection since she doesn't have satellite radio. At first everything worked fine for about a month, then after that, the car started popping the trunk in reverse. Now in the past week, the trunk has stopped working all together. Nothing opens the trunk, the little toggle, the fob, even going into reverse doesn't do it anymore. So i have it ghetto rigged and have connected a piece of twine to the trunk emergency release till she figures out this problem.
It just baffles me why this has been a slow progression with the only time i touched the car is to install the mp3 adapter. So I took the adapter out 3 days ago and checked all the wires behind the radio and navigation and nothing seems off yet the trunk still doesn't open. If it was a crossed wire or something, Im guessing that the problem would have started immediately after the install.
This is just soooooo odd. Also, I checked all fuses multiple times.
Anyone who can help is a life saver.
Thanks
