amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Sun Feb 17, 2019 3:44 am
You should cut a hole under the back seat to install those pumps with tank in place, once done no more problems and you can change a pump then in 30 minutes. What I did on my Focus cars.
I had no trouble with keeping the cars running at all, but it's the crap things that kept breaking, the cars are junk. Ford got reliable enough they let the rest of the car go to crap and little things break so much you get tired of it. On the Focus cars I kept a list of 'nuisance' breakage parts and got up to 50 things I thought should last longer than they did and I called Ford quits when I hit that number. My '02 had already broken several things by the time the car hit 50K miles, I changed all 4 window regulators twice and began to rebuild the broken ones myself as I could make those last longer than official Ford parts did. Same with door latch assemblies. I learned to take most of the broken parts and simply fix them for pennies to use again, they cost way too much to buy over.
The motors and transmissions last forever, but the rest of the car is crap. Nissan is beginning to look the same way.
