Trunk noise.... Again.
devlmaycry
Car: 95 Nissan 240sx S14.5
K, so I have a 95 240sx and it treats me pretty good, except the weird clunk from the trunk on bumps and stuff. I have all tubular and adjustable rear components, stance GR+ coils, and solid sub-frame bushings (made the noise before the solids). Everything is aligned and it drives well except for that blasted noise.
It's coming from the right hand side and I'm wondering if maybe it's the filler hose or something. The noise really doesn't seem to be sub-frame related like some of the other clunking I get. It sounds like a knocking that's in the sheet metal in that same area as the wheel well. I've looked and its not the tire rubbing, but I'm running out of ideas.
So, any ideas on where to look from the thousands of other dudes with 240sx random rear end noises would be appreciated guys!
kouki munster
Car: 97 base 240
Check the pillow ball mount at the top of the coilover, I know stance got a bad batch of thoes a year or two ago.
goldeneye9mm
Car: 95 S14 240sx
check all the bushings on the right rear. all of them. load them with a prybar or something to see how much they move.
nando
Car: 1995 nissan 240sx se
1989 nissan 240sx
maybe remove the trunk int. and check the wheel well... could be a screw driver or some thing in side... maybe?
devlmaycry
Yeah thanks for all the ideas already guys. I'm def going to check the dead space back there and the pillow ball. I should have some feedback for the troubleshooting some time tomorrow.
Keep the ideas coming!
