agreed. use your LOOKERS. that means EYES.hilux30 wrote:Did you even look in there, Its freakin easy and pealin a banana...
thanks for some actual useful information.... i wanted to look it up before i tried and see if there were any little tricks to it.94_240sx wrote:It could be tricky for some people. There's a clip holds the cylinder asembly. Use flat head screw driver and pop that thing out and swap.
If you have silvia lock, yes, you can swap the lock mechanism too. I did it a long time ago, and IIRC I used a small flat head screw driver to take out the internal. You have to bend a lip to take intenal out, swap and bend the lip back to seure. Your original key will work with silvia lock.
