Fosty »
https://forums.nicoclub.com/fosty-u284801.html
Sat Mar 04, 2023 4:24 pm
So I was delivering some boxes while at work, looked in the mirror and though "Wow, my window is clean"
It turns out there was no window because my back door had opened up.
The latch system on the actual car came off. I couldn't really see how it was mounted. I did find 2 screws with some slightly conical washers, but I couldn't see where they would screw into. I poked around in the hole to see if I could find some nuts, but no luck.
I've got two questions.
First: does anyone know how to mount this?
Second: is this facing the right direction? Most of the wear is on that side, and this is how the ones at the junkyard looked. (I went there to see if I could find an answer, but the screws were stuck and rusted).
I've currently got it zip tied, but there is too much wiggle. I'll try some JB Steel Stik or my stick welder if the proper hardware is too much trouble to get my hands on or install.
