tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Mon Apr 24, 2006 7:49 am
i just recently noticed my lever (s13) not working for the gas tank, and happened to notice that part of teh cable was broken (the plastic part that holds the outer tube onto teh levet bracket)
like $3 (and 30 minutes to rip out half the interior to get to the damn cable) later from a junkyard i have a whole new cable
youll probably have to take your seat out, but do that, then the sill and peel up your carpet, you should be able to see the problem
(and the sills are just a little tricky, its plastic screws inside plastic sleeves that hold them down. stick a flathead underneath to put pressure on the sleeve/screw, then unscrew it)
doesnt help your key situation much, but should help out
CJ
