Wes old buddy... could you post a picture of what you're talking about? I'm having a no trunk release problem on Q2... I hear the solenoid click, but it's much quieter than it should be - more of a "click" than a "clunk" ... I assumed that it was a bad solenoid.elwesso wrote:First problem... I vehad this happen on both my Qs, i assume you can open the trunk normally with the key, yes? If so, bend the little flap thing back... YOull see it by the latch on the car, when you look down at it.... If straight foreward towards the front of the car is 12oclock, bend it with a pair of needlenose pliers to like 1130 or so, just a little.... In other words, counter clockwise...
I think I know where it cracked. This might work, I saw somebody do this when the peripheral edge (frame) spot welds separated from the skin... Prep the weld area, then dam the edge off with duct tape or modeling clay, then run water from a hose over the area (top of hood) which would suffer from the heat. I'd only use .023 wire and spot it first to keep it from absorbing too much heat, then stitch it very carefully.At least this is what I'd do....Hope this helps.mattd1979 wrote:I am going to have to figure out a way to weld that crack up without damaging the paint on the serface from the heat.
Yikes !! .25 ?? I think you mean .023.mattd1979 wrote:Thanks for the info squeefoo.That sounds like a plan. That is what I will try. I will have to change my wire because I think I am running .25 right now.
