The "kit" consists of 2 trunk struts. That's it. The serial/product numbers are scratched off when you get them so you don't know what they are. I bought them from Jason about 8 years ago. They do work and pop the trunk all the way open, but for 160 bucks I would not do it again. You could probably call a company that makes trunk struts and find out what works for you.Debonair wrote:Mine works just as you describe yours working. I stumbled across THIS GUY who was/is making a kit that pops the trunk open on older M's and Q's. No idea what it consists of but it may work for the Y51 M's as well.
Thanks for the info. Good to know what is actually is included. I may have to take some measurements and locate some slightly strong struts.reggiebrown40 wrote:The "kit" consists of 2 trunk struts. That's it. The serial/product numbers are scratched off when you get them so you don't know what they are. I bought them from Jason about 8 years ago. They do work and pop the trunk all the way open, but for 160 bucks I would not do it again. You could probably call a company that makes trunk struts and find out what works for you.Debonair wrote:Mine works just as you describe yours working. I stumbled across THIS GUY who was/is making a kit that pops the trunk open on older M's and Q's. No idea what it consists of but it may work for the Y51 M's as well.
Not trying to ruin the guys business but he's been getting bad reviews on several forums. I would use caution if you decide to deal with him.
The auto-cinch is only on the 13+ models.Larz wrote:I actually fancy how it closes itself soon as it gets near closed and you let it fall. Not too hard, but hard enough to latch.
Take a look at the existing struts and see if there are any markings on it. It may have a number on it followed by a capital letter "N". If you find a part number (they may be from Stabilus - if so, their web site may have the info).ibc wrote:This other thread is for an older 2003 M45, but that doesn't look anything like the trunk struts on my 2011 M56.
I'll have to remove the parts from the car, and maybe measure the lid weight with a scale?
I'm not sure how else to get the proper lifting force for new gas-struts, rather than assume 80# happens to work on my car.
Any ideas on guessing lifting force?
I was not referring to any sort of auto closing mechanism. I was referring the way the boot lid drops after it is pulled far enough to drop under it's own weight. It does not slam shut, but drops onto the latch with just enough force to cause it to lock.Debonair wrote:The auto-cinch is only on the 13+ models.Larz wrote:I actually fancy how it closes itself soon as it gets near closed and you let it fall. Not too hard, but hard enough to latch.![]()
Yes, but I would not make the force too large - you may have difficulty closing the lid and also bend it if the strut puts too much pressure on the lid when it is closed.ibc wrote:Weight of trunk lid alone (resting on a bathroom scale) supported only by hinges, but without any gas-struts: 20 lbs
That's surprisingly low![/quote
Indeed, yes!
ibc wrote:Existing gas-struts:
Manufacturer: Stabilus
Labels: "015273 0460N 124/10 A33" and "84430-1MA0A"
Rod diameter: 8 mm
Tube diameter: 18 mm (3/4")
Extended length (between mounting point centers): 29 cm (11 3/8")
Stroke: 9 cm (3.5")
Initial/Maximum Force: 105 lbs / 110 lbs (ie, 460 Newtons)
Plastic sockets on both ends mount onto ball size: 10 mm
So I think stronger struts might be enough to lift the lid?
Hmmm ... possibly. But I'd be concerned about two things:ibc wrote:Don't you think this would be better?: http://www.asraymond.com/gas-struts.htm ... nit=metric
Man! Super easy access to both ends of the strut - I am jealous!ibc wrote:Base Cylinder Length = 26 cm (10 1/4")
Yeah, I certainly don't want to bend the lid. Fitting it into place seems easily doable, without any obstruction from the hinges.
Photos: http://imgur.com/a/GBpM9
ibc wrote:To busy having fun on vacation.
