You're going to get 12 volts to the switch whether it comes through the fuse box and electrical harnesses or directly off the battery with 2 jumper wires. What will freeze up the actuator in the trunk is touching the wrong two wires. Hence the need for a FSM. I know nothing about electrical to tell you which wires are it. Hopefully someone with an FSM and some electrical knowledge will wake up soon. Have another cup of coffee.cccpman wrote:.........but I think the battery might be a little strong to connect to the actuator, I dont want to have it shut on me forever and end up taking an axe to the trunk.
Hey check it out, if you do end up "taking an axe to the trunk", can you make sure you video tape that and post it up here?cccpman wrote:FSM is in the trunk too unfortunately . I understand what your saying but I think the battery might be a little strong to connect to the actuator, I dont want to have it shut on me forever and end up taking an axe to the trunk. I know I had a second copy somewhere, we will see what I can scrounge up in the garage
For the record, I was in for a $50 spot just to see that video, damn!cccpman wrote:brymax , an injector flooded the engine during start up, the starter was strong enough to throw a rod. It wont be needing a new trunk lid because its being parted out
mxr662 - I owe you, thats all I needed. I kept trying, never heard it click but went to the back to beat the crap out of it and it was open. Im used to hearing the click sound it makes when it opens. Anyways, great help, solved the problem
Just for future reference to anyone else who's viewing this thread... this schematic does not apply to the 1990 Q. This diagram is apparently from the 94+ manual, since it mentions a LAN.mxr662 wrote:
This might help.
I'm not sure what your mystery part is - but I would love to take you snipe hunting!gammer_ghn wrote:hey CCCpman so seriously what does that do the hydrostatic rod im so lost and im freaked because i loosend it and i dont know its function can you clear me up on the subject please?
