Got/added a spoiler? Could be someone swapped trunk lids with a J30t and your torsion bars are for the standard/lighter (sans spoiler) trunk lid?Paul Wall wrote:OK for your first problem, Your trunk torsion bars are worn out, Which I have never heard of but clearly possible like in your case.
Good luck an Happy new Year, Paul
Don't go!Paul Wall wrote:Damn, forgot all about the J30 spoiler.
I should stay in the Q45 forum.
No I never had a spoiler on it. As for the battery it's good and the light comes on. I did follow the lock all doors, pop trunk, put key in and out 10 xs within 10 seconds, manually unlock and lock driver door, hit lock on remote. Doesn't work. The trunk btw is a j30 not j30t unless the person before me changed the emblems. If those instructions are wrong plz let me know. Thanx...Paul Wall wrote:OK for your first problem, Your trunk torsion bars are worn out, Which I have never heard of but clearly possible like in your case.
And as for the Key FOB issue I would take it to AutoZone to see if the battery is good, But did you follow the instructions on programing it correctly?
If all else fails take it to pro help.
OK I will stay.GerryO wrote:
Don't go!
I have no idea what the instructions are for the Key FOB, I would search and see what you find or at least look in the owners manual or service manual available here: http://nicoclub.com/FSMsmartbeatz wrote:
