k-mart wrote:Yea, the unfortunate part was the lack of port area for the SQ port. I'm keeping my fingers crossed for no huffing......but I ain't bettin on it.
are those ports goin to be swappable? cause that's the best way of doin it, just use bolts/nuts to hold the ports in so that they can be easily swapped in and out... cause if you have room for the SPL port, then you should have more then enough room for the SQ one, cause the lower frequency you tune the port, the smaller the port...
what program you using to calculate the sizes? i used WinISD, a dope program which does almost everything for you...
