gameguru1360 »
https://forums.nicoclub.com/gameguru1360-u175323.html
Mon Mar 21, 2011 10:12 am
does it bypass the #194 plastic socket?? I noticed that the Racingline strip has that red socket to #194 socket, but also has that red plug on the end...does that plug directly into the #194 adapter?? I removed the plastic #194 socket and noticed a white plug on the end...I was able to disconnect the plastic clip. I'm hoping that red clip in the Racinling picture can hook up directly to the #194 wiring harness because then that would be ideal...no more worrying about the #194 adapter popping or slipping off every time I close the trunk!
