Ealge rods aren't that great... I'd suggest a good Carillo, Crower, or Pauter Rod set w/ ARP bolts. Nismo, Tomei, and Power Ent. do upgraded main and rod bearings for the SR20DET, if you have an S13 you can replace them with these.
If you decide to keep the crank you will need to have it machined and re-hardened. Nismo offers different grades of main bearings for this reason. The grades are for different degrees of resurfacing on the crank.
I'd just do a good build-up so your not faced with this problem again, and so that you can fully utilize that T51 turbocharger if that is indeed what you are running. Head mods are your friend with that turbo
