You know what my take is on this. So call up to the service department at the dealer and ask them?The Edge wrote:This is being discussed in "bluetooth/battery" topic but I want more exposyre for more replies.
If battery is disconnected does the i-key have to be reprogrammed by the dealer?
Actually, something just came to mind after I posted in the other thread.The Edge wrote:This is being discussed in "bluetooth/battery" topic but I want more exposyre for more replies.
OK so lets talk about the BCM and what would make it crap out?nissantech06 wrote:You don't have to have the iKey reprogrammed. The key itself has a chip in it that is programmed to the BCM, and the only way it'd have an issue is if your BCM craps out.
Name it LOL. There are many things, from adding aftermarket remote starts/alarms to it getting too much voltage...Urq wrote:OK so lets talk about the BCM and what would make it crap out?
The BCM is a computer that controls many miscellaneous electric systems in the car. Chances are, if it's not directly related to the engine, transmission, or emissions, it's processed by this module. Examples include the TPMS system, power windows and locks, etc..Urq wrote:OK so lets talk about the BCM and what would make it crap out?
...And I have had one of those, when the TPMS keeps lighting up even though there's enough pressure in the tires. There's a TSB out for it, it shows open circuits to the monitor of a certain wheel, the TPMS and the BCM need to be replaced and reprogrammed.Ever Victorious wrote:
The BCM can be damaged by anything that would damage a computer (static, impact, water, improper modification), but also some early BCM's on V's built before December 2006 will crap out on their own, just because. The problems have been fixed, and newer models (and newer BCMs) should be just fine.
