Trucks Leaning!!
JC87HB
Car: 1987 Nissan D21 HB
My 86.5 Hardbody is leaning in the front to the right. My right tire is experiencing accelerated/premature tread wear on the outside of it. Is something bent or bushings warped or shocks bad? Please help!!!!
RT
Car: 1991 nissan king cab pick up
could be a spring that has lost its spring rate. Kind of like being collapsed.The shock only dampens the wheel when it moves and how fast or slow it moves up and down. Sounds like a sacked spring. Take a look to see if something is bent or warped like it took a hit. If not spring has sacked out, meaning lost its ability to hold up fully. May need to have a shop check it out. They can put it in a spring rate machine and see if it takes the same pressure to move it fully like the other spring. Check all bushings and bee sure one has not totally crapped out. Bushings and ball joints can do this after many miles. Most likely a bushing or ball joint has disentegrated
JC87HB
OK well the truck is at 75k miles... So i was just wondering Ill get my Spring pack looked at...Cause that would make since cause my rear looks like it shifted to the left a 1/8" or so.. Thanks!
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You may be able to readjust the torsion bar back to the correct ride height. The adjstor bolt is in the crossmember where the Tbar is anchored.
Definitely get in for an alighnment afterward.
JC87HB
Thanks alot guys! i appreciate it. Ill check it out later.
